SignUp Now!Well why would Eric say what he said?The TTA chip has completely different fueling parameters, from warm-up O/L, idle rpm, through PE. As Carl said, timing changes for different heads. More spark advance from 2800 rpm on up and different boost values for the stock wastegate solenoid. The engine management for these cars is a "system" and changes to one or more component affects the entire system. The TTA chip was designed for the TTA system and the GN chip for the GN. I would not put a TTA chip in a GN unless your purpose is to test the knock sensor.![]()
Eric for me your assumption was correct. I guess I should've worded my question better. Thanks!Sorry, I made the assumption that the question was about "my" chips. Carl and Dennis are talking about the stock chips.
