Where did you get that steering box and what is the weigh saving
SignUp Now!What do they do besides look different.
are they anything like these.
http://www.scandc.com/suspensions.htm#streetcomp2
The steering box is off a S-10.. i later changed to a TRZ manual rack and pinion.
If i had to do it over again i would have left the power steering on![]()
Those arms are made by UB Machine. My question is, are they the same ones that fix the suspension geometry or just OEM replacements?
I called UB Machine directly and had mine custom made to specs designated by a guy named Michael Crawford who runs a grass roots shop called Hellbilly Hotrods. They will improve suspension geometry just like the SC&C arms, but require you to use shims to do your alignment. They also use 80's Chevy C10 upper ball joints which are beefier and 1/2" longer, but have the same taper. I also got 1/2" longer lower ball joints from PowerPerformanceMotorsports.
I have them installed, but the car is still apart so I have no idea exactly how well it will work when it's all together.
is it because is mostelly a street car?My car is a race car an I want to lighting up and I considere going with s-10 steering box.
Yes, steet car.
Not sure on the weight savings of the s-10 box, but its several pounds and cleans up the engine bay
went on there site now proforged, but couldnt find the part # for lower ball joints, do you happen to have it? and price would be great help.
thanks
Dave
proforged
The tall lowers are part #PROK6145.5SP
The tall uppers are part #PROK5208.5SP
I had my UCA's built custom so they use the upper ball joints out of a C10 from the mid 80's. That way my tall ball joints are a standart part #. The lowers are the tall ones mentioned above.
Don't put the tall uppers on stock UCA's. They will bind. I think they used to sell UCA relocation kits, but it's a bandaid. I would rather get the correct UCA's for what you are doing.
