tubular upper and stock lower front control arms
67gsconv
67gsconv
Hi, I have a question. Can you run tubular upper with stock lower front control arms? i have polyurethane bushings for the front suspension, stock springs, shocks, and sway bar. I don't know a whole lot about this stuff. I was thinking about G Body Parts tubular upper and lowers. It is an '87 Turbo T and I was just wanting to get better handling than stock. My budget is kind of tight and that is why the question of running the tubular uppers and stock lowers. I don't want it to be adjustable but just solid. And, I hope this question doesn't sound dumb and thanks for any help.
67gsconv
I cant imagine a fitment problem, ive read about others mixing aftermarket brands as well. I looked at gbody, but ended up with spohn. I think they were the next cheapest set.
Sent from my SM-N900P using Tapatalk
The GBody arms have the same dimensions as stock arms. The only improvement in handling would be from having new bushings. If you want better handling, but the budget is tight now, just put new bushings in the stock arms, and save up for a package that includes tall ball joints. Fixing the geometry will give you a huge improvement in handling.
I have a new set of spohn uppers i will sell you cheap, they have additional caster built in and they correct some of the camber change that causes bump steer. Only reason for selling is they dont tell you on their website they wont clear gta wheels without grinding some clearance on the ear around the ball joint and they wont take them back. i ordered uppers from a different manufacturer. Most of the lowers out there are heavy duty but the same geometry as stock, the uppers are where you gain handling and weight loss. I also have a set of tall ball joints for more camber correction, the new ams i bought came with ball joints in them. Pm me if interested?
Not true...
Raising the lower pickup point to a move even level with the tie rod pickup point is what aids in fixing the bump steer..
also, I have a set of almost brand new SC&C Double adjustable upper control arms with the extra tall ball joints, AND tall lower ball joints with the progressive rate jounce bumpers that I am looking to sell. FYI SC&C were the first guys to use the taller ball joints to aid in correcting the geometry, everyone else is trying to replicate what SC&C did in the first place..
Here is a write up explaining exactly the causes of Bump Steer...
With that said let's begin with the basics of why we may want to buy new control arms for our cars...
1) Bump Steer- causes, effects, and how to correct it
A) Our cars use what is described as a SLA front suspension. This stands for Short Long Arm. This means that our lower control arms are longer than our upper control arms. Our suspension pivots along certain points called Pickup Points. A Pickup Point is the pivot axis of each bushing, center of the ball joint, and tie rod ends. All of these are PP's that the suspension travels along. This means that if you were to look at your suspension from the front, the suspension pivots on these PP's and the location of the PP's create certain arcs, or paths of travel, that the suspension will move along.
B) Bump steer is defined as "..an unwanted change in wheel direction or toe as the suspension travels."
C) As our suspension travels through its' arc the lower control arm pivot point and the tie rod pickup point swing in an arc as well (because they are Pickup Points of the suspension-they are the pivoting axis along which the suspension may travel). If the arcs of the two points-the LCA (lower control arm) PP and the tie rod PP are at different heights, they will have different arcs. This is illustrated in the following drawing from Jerry Bickel's book:
You can see how the tie rod PP and the LCA PP on the spindle have arcs that they swing along during travel. In the picture it shows the tie rod and LCA PP's are almost the same height, which allows them to have an almost parallel arc. The near-same height of the LCA and tie rod PP's allows for an almost zero-bump steer situation, because their arcs they swing along are almost parallel.
D) Bump Steer in our cars is caused because our tie rod and LCA PP's are not at the same height. To quote Bickel, "Any differences between the spindle and tie rod arcs will cause the tie rod to push or pull on the steering arm. This changes the direction of the wheel, creating bump steer." In a suspension with the LCA and tie rod PP's not equal heights, as the tie rod moves and pulls on the steering arm, it is causing either toe-in or toe-out (this is where the actual direction your wheel is pointing is changed) and thus the change in direction of the car. Here is another drawing from Bickel's book discussing this:
E) How do we fix this bump steer, now that we know what can cause it?
a) To fix this issue we need to find control arms that help to relocate the LCA PP to a more level position as the tie rod PP sits. A good example of this would the SPC LCAs with taller ball joints that are offered from SC&C. This design does not simply add a taller ball joint and calls it a day, but it physically locates the ball joint to a more favorable position for suspension travel-locating it to a more level height as the tie rod sits when you use the taller ball joints offered with the arms, improving the arc the PP swings along relative to the tie rod. This LCA also addresses caster and camber issues as well, but I won't touch on that right now.. Once we have a lower suspension that has the tie rod PP and the LCA PP to a more level height, we can significantly reduce and almost completely rid ourselves of any bump steer the car may have. Note: simply adding a taller ball joint to the LCA will not fix this issue. The actual physical position of the ball joint must be changed as well. This is what separates suspension pieces like the SPC lower control arms from the rest of today's offerings- they physically change the location of the ball joint AND use the taller ball joint to locate the LCA pick up point and tie rod pick up point to a more level location. BEWARE of other companies products offering taller ball joints- you must make sure that they are changing the ball joint location as well, which is the real key here.
In my next post, when I get some time, I will go into the coilover vs shock and spring comparison...
67gsconv
Absolutely no problem running tubular upper with stock lower. I've been running that combination for probably 10 years. :)
Cool story, good luck with your sale.
Cool story bro.
I posted that info so that the OP could learn what helps fix the issue, hopefully educate himself somewhat with what was written, and make an informed decision on what to look for in parts.
Best of luck OP in finding what you need!
Not true...
What you asking for arms?
Cheap Speedway upper tubular control arms and stock lowers -- been working good for about 2500 miles.
and had no issues when it was aligned.
Did you sell them yet? PM me if available, please.
67gsconv
Hi, We specialize in G-Body suspensions and deal with customers every day pointing them in the right direction..
First things first, What is your budget? Once we establish that we can recommend the best way in achieving your goals with the car. For starters we have a "Complete" front & rear entry level suspension that you can autocross with for only $2,500
