m3x1c0
Bad luck Buick
- Jun 16, 2014
Anyone know a good place to get my GN tuned? Car has a MAFT Pro and was set up for E85. Trying to tune it for 93 since E85 is tough to find where I'm at.
SignUp Now!Have the exact same setup but was always tuned on 93. You have a wideband? You can get it close just by baselining everything, and then slowly working your way up. Datalog with a laptop to make sure everything looks right over a few days and then start turning the wick up a little at a time until you get close...
If you find someone in va that tunes translator pro's, please keep me posted.
I'm in Woodbridge va btw
I only have the TunerPro software loaded on my laptop so I can't see the log file.
Do you have a wideband? I would add an AlkyControl system to the car if you plan on running it hard... Whats the setup on it? Edit your signature and add what you know about the car so its easier to help. And I don't know how much you know about these cars but there is LOTS or info here and on the other site. Also Vortex Buicks is a good one for troubleshooting.
Looks like the power logger has more features but I finally found a serial to usb cable to try out the Maft-Pro Logging. Besides tuner pro RT aren't there some support files I need to run it? And will running it to my laptop mess with the current tune at all? Don't want to plug it in only to find out I have to learn everything about or else my car won't start lolYep... That's it. Allows you to write/read directly to/from the translator pro and does data logging...
