tuning alcohol
jay jennings
have Julio's kit on my 86t, when the alchol turns starts spraying I get detonation at wot, if I use my normal tt chip without alky wot no problem,tried to tune the original chip to no avail, ordered a new tt chip for alky and my setup still getting detonation when alky starts spraying, motor cuts out etc, is there a step by step process in which I should tune, using scanmaster....
At the top of the alcohol section there is a sticky thread that explains how to tune with alcohol. It's very imformative
Need more info..
What MAF is used?
What are your BLM's at idle and cruise?
What are O2's when the kit starts to spray?
Are you having surging if you hold the boost at part throttle like 8-10 PSI?
What are plugs gapped at?
