NicksTurbo6
- May 25, 2006
Last night I took the GN out and the outside temp was in the mid 40's, AIT
reading in the low 50's. I run a TT chip with 60s, Racetronix 340 pump and
sender, hotwired, FP 45psi line off, 17 PSI on 93 pump. Last night the AEM wide band went up to
12:3 and rising, so I quickly let off, picking up 1.9 degrees of knock on the SM. Last time I drove the car was about a month ago. Temps were still in the upper 60's, low 70's, and I was good using the default setting in the TT chip for fuel (128) and getting an AFR of around 11.5. When I got back home, I went in and added 10% more fuel WOT to try to get back to my target AFR, but did'nt have a chance to take it back out for a test flight. What are you guys having to do to your tunes for the cooler weather? Is adding around 10% more fuel not out of the norm?
