hemi8
Goin Sideways
- Jun 6, 2001
Took the GN out for its maiden test drive with razor's alky kit this morning and all I can say is you cannot wipe off the smile from my face. I am right at 20 psi, no knock on Casper's gauge but from my O2 gauge and the EGT gauge I am running lean. I was seeing 670 O2 and over 1600 egt, I pulled out of it and pulled over and bumped the pressure up to 46 psi up from 44 psi. This brought the o2's to 710, I still see no knock, the egt's came down below 1600. Question is this, at what point do I stop increasing the fuel pressure and start adding fuel via the TurboTweak 93 Alky chip? I run 50 lb injectors, Red's twin fuel pumps, (hot wired).
Mike
86 GN
Mike
86 GN
