turbochargedv6
- Feb 10, 2004
Well here we go, I have new injecotrs and matching chip from caspers. The injectors are msd 50lbs and have the walbro gss340 and adjustable fuel pressure regulator which is set at 43.5 with line off. I have new iac and tps and have them set in the area they should be and the 02 sensor is new, my maf is 8-9 a/f on the scanner which is high. I basically have a surge in the idle only when it warms up, cold is fine and it starts right up. I have the thumbwheel set for stock right now and in my search on the site I have read check the ve numbers. I need to know what does ve stand for? clueless have learned a lot about these cars in the last year but I am sure I will be learning a lot more in years to come. I need someone to explain if they can about what to check and in detail no abbreviations please?
BLM 115
a/f 8-9 high stock maf with k&n filter 9" connected in front of maf
tps .44
iac 15-35
o2 numbers jump around too much, It is not on the road yet and want to get everything tuned decently before I put it on the road and it is also ****ty weather in rochester, ny so rather wait another month before I do, don't want the salt to eat my car up. I did have a few leaks with the exhaust and turbo inlet but all are fixed and I have no vacuum leaks. I hope I included everything you may need to help me if not let me know and I will get right back to you. Thank you in advance and at least I can say for now it's getting better thought it never would for a while.LOL
BLM 115
tps .44
iac 15-35
