tuning question
JSD69Vette
Before installing a WB, I was using my Trans+ and going off O2mv. As a result I added fuel to the tune using the high load page of the Trans+.
Since getting the WB, I've set the Trans+'s AFR tracking feature to add the fuel for me.
Here's my question, I HAVE NOT removed the fuel I originally added in the Trans+'s High load page, should I?
Thank you very much for your help.
I am not sure if it helps but follow what the wideband readings are intsead of the o2 count.Reading the o2s are not accurate.I would think you would need to figure out the a/f ratio and adjust from there.
