imjoesnuffy
I just break stuff!
- Sep 13, 2005
Need a lil help with this. Well I have recently developed a sputter/backfire.
New NGK5s gapped at 35
New Taylor made Thundervolt 50s
87 Coil conversion coming this weekend.
Scan numbers:
TPS .46 at idle, 4.7 at WOT
IAC 28 at idle
BLM = 150???
INT = 128
O2 volts at idle .10 ish, WOT .93
Can't get it to idle less than 975/1000. No matter how I mess with the IAC screw.
Any suggestions? TIA
Sputter/Backfire usually occurs at part throttle.
One more question, what size is the stock DP? Think I found a set, want to make sure they will be an improvement
Scan numbers:
IAC 28 at idle
BLM = 150???
INT = 128
