Squid4life
- Jul 5, 2004
Okay, trying to get this thing tuned correctly so I can finally start playing with Razors PAC alky. I have always had KR, whether it is false or real eludes me. Why it knocks sometimes and not others confuses me. Why it will hit 2-3 degrees of KR at half throttle then go completely away at WOT also confuses me. I need some help here...
I was running rich so it was suggested to drop the fuel pressure a bit so it is now 42 line off. No change really.
Here is some info:
Idle
750 RPM
166 coolant temp
134 MAT
122 BLM
128 INT
TPS .45
O2 832
LV8 38
Volts 13.3
O2 X cnt 0
IAC 11
MAF 5
WOT 3rd gear pull:
3750 RPM
162 coolant temp
98 MAT
128 BLM
128 INT
TPS 4.66
O2 844
LV8 128
Volts 13.3
O2 X cnt 0
IAC 119
MAF 255
On a 2nd and 3rd gear pull I will usually get about 6 degrees right at the start (tranny mount getting ordered, exhaust tailpipe adjusted) then it will drop to 1.1, 0.7, 1.4, 1.8, 2.1, 0.0, 1.1, 0.0, etc. The whole time the O2s are 871, 852, 852, 844, 832, 824, 824, 813, 813, 801.
Am I too rich? I don't want to drop fuel pressure too much lower than the 42 line off I am on now. Should I ignore it and chalk it up to false KR?
New plug wires, plugs 1000 miles old, coil pack ohmed out fine, TPS within limits, O2 sensor new ~1000 miles ago.
At idle the O2s used to jump around, but since I dropped fuel pressure to 42 they seem to stay at or above 800. WTF?
Any help, ideas, suggestions, donations, etc would be greatly appreciated.
I may be able to transfer some TLink files from the cheesy laptop to my PC if someone wants to take a look. Really want to get this damn thing KR-less so I can play with the alky.
Here is some info:
Idle
750 RPM
166 coolant temp
134 MAT
122 BLM
128 INT
TPS .45
O2 832
LV8 38
Volts 13.3
O2 X cnt 0
IAC 11
MAF 5
WOT 3rd gear pull:
3750 RPM
162 coolant temp
98 MAT
128 BLM
128 INT
TPS 4.66
O2 844
LV8 128
Volts 13.3
O2 X cnt 0
IAC 119
MAF 255
