My first run with the GN after all the mods were done was very disapointing.My best run was 13.55 at 98mph.With all the mods I put into it I was expecting a high 12 second time.My mods were as follows:3" dp,walbro pump with hot wire kit,adj wastegate,razors alky,36lb injectors,TT alky chip,accufab fpr,275/50-15 MT drag radials,cold air kit,scanmaster,stock exhaust.The fuel was set at 42psi my first 3 runs and had no knock at all at 18lbs of boost.I kept the same fuel pressure but increased the boost to 20lbs and went slower.The car felt like it was being held back and just fell flat in third gear.Car was backfiring.Still no knock and the O2 was around 800.I had to leave the track when my wife called hysterical that our son had a temp of 104.5 and was having seizures.So I made the 2 hour trip to the hospital.The car idoled like crap the whole way home.I found when it backfired it blew the screens off the maf sensor.I replaced them and now the car idols fine but if I put it to the floor it still backfires and runs like crap.The car really feels like it is being held back.I think the exhaust might have something to do with it but what fuel pressure should I start out with?Any advice is greatly appreciated.Thanks,AJ
