Turbine Housing
pontiac6269
I took my original turbo apart to maybe rebuild it and found a crack in the housing. I'm guessing this is no good now.:frown: Had to use white chalk to make the crack show up better in the picture.
Thanks,
Eric
be glad you found it before you damaged any of the blades, is that your stock turbo?:confused: if so i might be able to help
Yes it's my stock turbo, I have another stock turbo on the car that I bought off a member on the TurboBuicks board that was rebuilt but is leaking oil into the compressor housing.
i should have a stock turbo around, i'd have to look for it but it had no leak issues just a bad blade, your welcomed to it, just pay for shipping if i find it , if you like
