This is a theoretical question. Please don't tell me "Don't do this," I know.
The actual "work" done by a turbine is determined by the pressure ratio from the inlet to the outlet, and the mass flow through it right?
In looking at Turbine flow maps from Garrett, I think another principle is a given turbine will only flow a certain amount of mass flow though it. As more "work" is needed by the compressor, not much more mass flow travels through the turbine, rather the pressure ratio goes up, providing the extra power.
So if you had a REALLY small turbine, say a small T3 turbine wheel and .36AR, and had it connected to a big compressor, say a T66 wheel. To maintain enough "work" to keep the compressor going, it would still be able to do it, BUT it would require a insane amount of backpressure in the inlet.
So a turbine designed to flow only say 6lb/min of mass flow, was connected to a compressor flowing 72lb/min of air at 29psi (3:1 pressure ratio), should require (give or take) the following at the turbine:
72/6=12
3*12=36
36:1 pressure ratio
36*14.7=529psi
529psi at turbine inlet
6lb/min mass flow
Right?
Obviously, you can see why it's a bad idea to have a way too small turbine, the backpressure would kill the engine. But what if it was 6 lb/min of CO2 gas at 529psi? See where I'm going? CO2 powered turbo.
72/6=12
3*12=36
36:1 pressure ratio
36*14.7=529psi
6lb/min mass flow
Right?
