Turbo 400 swap
DEL
I'm thinking about converting to a TH400 in my 86 T-Type. It's spends most of it's time on jackstands anyway, but of it's actual driving time, it's about 95% drag racing and 5% street cruising so comfort is not a concern.
I'd like to build it once, and it will include a trans brake, etc.
What if any driveline or cross member changes are there? I assume I will need a new flex plate? Any info is appreciated, I need to know what to budget for.
Modified my mount, same flexplate not bad at all. Same crossmember
You'll need a different length driveshaft and a larger slip yoke as well.
TH-400
As you said above, with street driving out of the question go with the 400. I can't tell you how nice it is with transmission blues out of my mind.
Love the T-brake. Just make sure to get the right convertor.
Ted
Originally posted by VictoryTrans
We have a 400 converter for sale if your interested:)
Yeah, if you get a Neil Chance convertor don't talk to Marty down there. I've had mine in and out 3 times and finally had to send it down there to have a new pump built.:mad:
