turbo bolts and gaskets
deadlois
Anybody know where I can get the downpipe-turbo bolts or just get them from homedepot? Also do I need gaskets on that connection(tdownpipe to turbo) or just some copper RTV will do? I noticed my crossover pipe needs to be realigned, is there an exhaust gasket I should use for that? Thanks for any help.
Those dp bolts you can get at any hardware store. Make shure you get the ss bolts.
Usually the dp you don't need gaskets, the RTV will do fine.
On the crossovers there is no gaskets, just make shure you tighten the bolts evenly.
John check your pm
