What is the largest size drain you can run on a turbonetics? I ask this becuase the cartridge is off set torwards the compressor compressor cover.
Can a -12 be used.. if so.. what drain flange and and fittings were used. Aluminum adapter with 1/2NPT then a barb or an aluminum adapter with the AN?
Turbo is a 76 GTS 4 in 2.5 out
