Turbo for 84HA GN???
Donniejr81
I'm in the process of aquiring parts for my 84HA engine build. The stock turbo is now RIP. Bearings and impellers look like Godzilla used them for a teething ring. So, I guess I'm in the market for a replacement. I have a good turbo off a low mileage 87GN is that a feasible replacement, or am I better off selling it and putting that $$ toward a replacement hot air turbo? The 87 turbo is slightly larger i noticed, and looks like it would work if I clocked it and got an adapter for the outlet-to-intake. Any ideas??
If you are thinking of using the stock 87 turbo on a hot air it can be done. A custom adapter needs to be built and the turbo reclocked. A rebuild on your stock turbo will be around $500. The TA33c will run a little over $900 which will flow around 300 cfm more than a stock hot air turbo. Good luck. Brad
