Squid4life
- Jul 5, 2004
So I go out tonight to get some Tlink readings, go out make a few passes, then come home to look at them. When I select "REPLAY DATA", I select the runs I just made, but the version reads "3.X" instead of "4.0.5" like the rest. When I try to open them, it says it must be converted, so I resave them as the original name plus "b" (easeinto1b) and they save as 4.0.5, but are totallay garbled. It says I am running 22.6 lbs of boost at idle, which is 0 rpm, coolant temp is -40, 0.0 volts, 0 ESC, etc.
I assumed I needed to re-calibrate the boost harness, but that wouldn't explain why I have to convert from 3.X to 4.0.5. Why is it saving them as 3.X?????????????????????
