Turbo Link problem
V6POWER
Senior Member
My TL is misreading MAF and O2 at WOT. During normal driving it reads correctly. It should be reading 4xx for MAF but is only going to 28x. The O2 readings should be 700s but it is reading all over the place. Real low (78) to only 6xx. I have a Translator, LT1 MAF and Extender chip. Any help is appreciated.
With the Extender, your MAF readings are going to be half what you would expect. In other words, if you expect to see something in the 280's, you would see 140's. Expected: 380, reading: 190.
Can't explain your strange O2 readings though, unless the sensor's going bad.
I have the fast update and the MAF used to show in the 400's. Now it only shows 280's. Thanks for the response. :)
I'm trying to understand how the maf could have been showing in the 400's with an extender chip? oh well.
