turbo motion V2 intake install ?s
85 ttypewh1
fire fighter
Intake is on but i have a few ?s. What bracket is used to mount the tv, cruise and throttle cables to the intake. I have a stock 85 and 87 can they be modified to work. Also how does the wastegate bolt up to the turbo, where i need mine to be the wastegate bracket hits the turbo outlet. Any pics or directions would be great. Thanks
Greg
I have another problem, the iac motor. I used the fubar t stat neck and the iac still hits it so i cant bolt the t/b on. I used my stock 85 iac on the 87 t/b is that ok or is the 86-87 one different. Thanks. Hope to get this done sooner or later.
My turbomotion kit had the thermostat housing modified. It basically looks like they took a stock one, cut it in half, then welded a flat plate on the top to make clearance. I will take pics as soon as I get it dropped in for you.
Matt
