Turbo oil feed line
gn dennis
Mounting a new TA49 turbo I need the oil pressure feed line. Where should I go to buy? Or should I make one? Thanks Dennis
Kirban's has the OE steel line, made by Classic Tube - part # BUO1014-OE. If you want a stainless steel version, have to order that direct from Classic tube, part # BUO1014-SS
classic's website shows 10% off today with code SHOP NOW.
https://www.kirbanperformance.com/product/176/OIL+FEED+LINE+to+the+Turbo+#1588.html
https://classictube.com/?s=buo1014&search_id=1&post_type=product
these are both available from Summit albeit at much higher prices as shipping cost from Classic is built into the price - item is drop shipped from Classic but Summit will add $9.99 handling charge. buy from kirban's or Classic directly.
There is a stern warning on the SS line just in case you are in California.
WARNING: Cancer and Reproductive Harm
I would like to use a braided s.s. with the 180 deg. bend in top that attaches to turbo and the fitting that goes into feed tap at engine block. Thanks everyone. Dennis
