turbo oiling
t3intercooled
I know my stock oiling system for the GN operated and oiled my stock turbo perfectly fine. Now I purchased a PT61 from precision and was wondering I can use the stock oiling system on that right or do i HAVE to go to something like the Turbosaver? Also where can I get a new stock replacement oil feed line?
You do not need a turbosaver or anything like that for your PT61.
I believe Johns Performance (dot com) has new replacement oil feed lines.
During installation of new oil supply line leave it loose at the turbo. Crank engine (do not start) until oil comes from the supply line. Then connect it to the turbo.
This will insure the turbo bearings have oil to them without having to wait for the line to fill. I always squirt a slug of oil into the turbo fitting before attaching the oil line.
Bob
