Turbo Olds 350
87bigcut
First off, if anyone is annoyed that I am posting this here please tell and I will stop, but this seems to be the best turbo board around.
I am looking to build an Olds 350 with a turbo setup if I dont swap in a 86-87 GN motor in the next couple of years and I am pondering a few questions:
1. Is a single turbo set-up easier or harder to do that a TT setup in a g-body? And for either what size turbo should I use? I will try to find out from some olds guys how much power the bottom end will handle.
2. What should the headers be made out of?
3. What is a good EFI conversion, and should I use a doghouse 90 degree bend with a throttle body or use a carburator style mounted 4v throttle body?
4. Has anyone here used a megasquirt EFI system, or know of any comparable systems?
Thanks,
Joe
Trans Plant
I own a blue 1964 buick skylark sprecial. Best time 10.36 at 127mph. 109 block turbo 400 and 330 12 bolt. Stage motor in the works,will see 9s:cool:
Join realoldspower.com and do a search on turbcharging. There are several guys over there doing it.
