Turbo Q's??????
WICKEDGN
I CANT LIVE WITHOUT BOOST
Will my stock 87 gn turbo fit a hot air setu?????:confused: if so how can i do it do i have to order something or clock the turbo.??
It will work
The turbo will work on the stock hotair setup. reclocking the turbo is easy. Just losten the bolts on the outer circumfrence of the compressor side of the turbo. The only think you will have to figure out is rigging up some kind of adapter so the turbo will plug into the intake correctly. And I know for sure that there are guys on here who can help you out with that. HTH :)
