Turbo question
rctrooper1
I just recently purchased a GN. Upon detailing the engine compartment, I noticed some oil residue leaking from the turbo area. I removed the hoses and found oil residue in the hose leading to the intercooler. I was told the turbo needs to be rebuild. First question, where do I get a rebuild kit? and how can I tell which turbo it has? I dont want to assume it has the oemturbo. thanks in advance.
jz.
Other possibilities are the oil feed line, the gasket between the turbo and oil return line, also the return line itself. Check them out first.
