Turbo Question
rob nolan
I was wanting to know because i am up gradeing to a bigger turbo. would a TA62 be a good turbo to up grade to. i still have a stock converter in but this winter i'll put a 3000 stall in and have the transmission rebuilt. my mods are listed below.
with the mods you have I'd go even bigger. I'd say 63,64,45,or 66 and a 3500 converter.
how would the driveiblty be on the street. i drive it more on the street than anything. and go to the track every now and then. thanks for the info.
how fast do you want to go? (BTW, 3000 stall ain't enough for a big turbo....even a semi big turbo)
i would like to run 11.00. what size converter do you think i should go to.
3600 and a TE-45 will get you that and more......
good luck
i know but a $1000 for the turbo and how much for the converter.
i just don't have $2000 for both now. i have about $1000 now to spend. and i was going to wait until this winter to do the transmission and converter. i still haven't took the car out to the track to see what it will do with all the mods. i have the turbo sold. and i was wanting to take the car out to the track before the end of the year.
I'm running a john craig te-61 turbo w/ pte exhaust housing & a 3200 rpm stall 9/11" converter (1st gen art carr)
Car pulls like a beast off idle (mid 1.7 60') & has excellent street manners. I've gone a best of 11.43@119.6 so far with this combo (still running a street chip & xylene homebrew, 22lbs of boost.) With the extra mods your car has (better heads, bigger injectors, fmic, etc..) this turbo & converter combo should have the juice to go solid 10.6's in race trim.
Doug C.
Doug C.
how much did you pay for the TE61. i talked to someone there at limit engineering today and he ask me if i want a TE or TA 61 or 62 its just the TA is stock appearing. just want to be sneaky about the turbo.
I say go for the TE housing, the integral inlet is better flowing than a TA housing! Unless it's a fellow Buick guy or your parked next to a bone stock T, 9 times outta 10 no one will know the difference anyways. :)
I think "list" was around 725~750 or so for my turbo, should be a bit less if you use a garrett exhaust housing.
I'd advise saving up an extra couple of months & doing the converter & turbo at the same time. ANY of the 50 & 60 series turbos will have SIGNIFICANT lag with a stock converter, which will get VERY frustrating in no time! A 9/11" from Performance Transmission should run ya around $600 so you're only looking at ~ $350 over your current $1000 budget. ;)
Doug C.
Doug C.
thanks alot with the help i'll call and see about the TE61 PRICE
