I just called & told 'em what I had; I think it was the T3-T4 series complete rebuild kit (its been a while ago) & I requested w/ *270 dynamic bearing seal. I think I had some bits left over but better safe than sorry
The rebuild was not that difficult, basic tools & very, VERY basic skills (right up my ally) You do need extra long snap ring pliers if I remember correctly...
The thought of tearing into the turbo is intimidating; & R&R can be a PITA; but the actual rebuild was pretty straightforward.
I even polished the cold side while it was apart, I bought an aluminum polishing kit at Harbor Freight & used a table top buffer/grinder... after sending the cover across the garage a few times
I got the hang of it & learned how to buff-out contact dings in the process!
I'll probably use a Dremel or air tool next time & put the thing in a vise
Here's what I found on their site They have an exploded view diagram w/ parts listed they include in ea. kit I copied it for reference during the rebuild
Complete T3 Kit:
#1 Journal Bearings
#2 Retaining Rings for Journal Bearings
#3 Piston Ring for Turbine End
#4 Thrust Bearing
#5 Thrust Collar
#6 Seal, YOU SPECIFY TYPE (See Above)
#7 Seal Ring for Bearing Housing
#8 Thrust Spring for Backing Plate
#9 Thrust Spacer (only used in 4pc Carbon Seal Kit)
#10 Locknut for Shaft
#11 O-Ring/Gasket for Compressor Housing
#12 Bolts for Compressor End
#13 Clamps for Compressor End
#14 Bolts for Bearing Housing
#15 E-Clip for Swing valve
#16 Lock Plates for Turbine End
#17 Bolts for Turbine End
#18 Clamps for Turbine End
Complete T3 Rebuild Kit
Price: $96.00
HTH!
D
