I'm wondering what I'm dealing with here and any help is great. I have the famous turbo snort when under throttle and then let off the gas, but what I don't understand is that it happens all the time, even under normal driving conditons (or those where the turbo kicks in a little bit...and I mean just a little bit) that I get the back snorting or back pressure. I know it's the turbo back pressure of exhaust gas and that it can be real detrimental to the turbo's bearings, but I barely get into it such as passing on the road and it does this. Do I need some sort of pressure relief valve like ATR used to sell or what. My mods are the usual street items like adj fuel, 204/214 flat, RJC, 340 Wal, Hot Wire, ported heads, 65mm TB/plenum, 100 lb springs, 36 lb'ers....but to be honest with you, I'm not sure what turbo I have. It could still be the factory Garrett, but the 49's have Garrett stamped on the housing also :redface: I'm reading 0 knock all the time and have plenty of power...I just don't wanna bust something up on my very menial budget....thanks fellas!....Glenn
