Turbo V6 Engine Parts: Complete Rotating assembly, Pistons, Crank, billet caps, Turbo, Lifters_$1,234
BUICKTIME
It's ah me, Mario!
TurboBuick.Com Supporter!
Rotator came out of a perfectly running engine that was taken out just to change the camshaft but with my luck I found a crack in the block and now parting out the engine. The engine and parts below have approximately 3k miles (*unless otherwise noted). I have plenty of pictures I can send on request. PLEASE do NOT waste MY time, serious buyers only, PLEASE!!! Don’t hesitate to ask any questions. Preferred Cash local pickup, especially for the bigger heavier items. Local pickup is Oceanside (Long Island), NY 11572
– Complete Rotating Assembly: 40 over Diamond Pistons, Scat Hbeam Rods w/ARp bolts, stock crank (10 under- rods & mains), balanced flywheel (SFI exp.) and balanced Harmonic balancer (complete externally balanced rotator)_$1,600
– TA/Morel Hyd. Roller Lifters TA-1412_$400
– Scorpion 1.55 Roller Rockers for GN1 Aluminum Heads (complete set with the correct center/off center & guides)_$400
– Turbonetics 6965 (8 bolt compressor housing) 4 bolt exhaust housing with V-Band in great shape (this is a bada$$ turbo)_$850
–SOLD- 4x Billet Caps (2 centers, rear and front Main Caps)- USED_SOLD
– Stock Crank- cut .020 mains & .010 rods (will need to be cut)- (*mileage unknown)_$250
– Stock Rods and pistons (*mileage unknown)_$150
– STAGE 2 Off Center- Ross pistons (4.020”) and 6.5” Carillo rods- ONLY 4 PIECES, hard to find and make for great back-ups (*mileage unknown)_ $200
more pics
