bobs84ttype
- Nov 24, 2006
I am studying the operation of the systems on my car. just want to verify i understand how the solenoid works.
I believe that the solenoid must measure the manifold pressure and when it reaches the value on the chip the ecm operates the solenoid.
is this the only refference the ecm gets on manifold pressure?
is this done by applying manifold pressure to open the gate once psi is met?
does manfold pressure override the spring pressure in the actuator?
does the solenoid remain open to bleed pressure untill psi is met then close or does it remain closed then open to apply pressure in a positive action.
Robert
Robert
