Yep ... they all seem to be "backwards" compatible to USB 1.x, so it's more dependent on the USB device used.
BTW, there are some pretty crappy USB/serial adapters out there ...
HOWEVER, we are right now testing a major driver code change that seems to get around some of the "tricks" they play. We've now been able to test with the Belkin F5U103 adapter successfully (we couldn't before) at both P4 and C3 line speeds.
We have another unit (a Delou) that seems very promising and a lot less bulky than the Belkin.
When we do some more testing, we'll post on the TurboLink Discussion Group a list of tested and "approved" adapters (and a list of ones we know don't work no matter what).
We've found three major chip sets are used:
1. One set doesn't work at all with P4s since we can't get it to properly support the baud rate. Nothing we can do with these, since it's in the firmware.
2. One set does some wierd things at the oversampling rate that we use to talk to the C3 ECMs, but the code we are testing has found a way to compensate for that. It works fine at P4 speeds.
3. One set works great at the C3 speeds, but does some funky buffer handling at the P4 speeds. Again, the code patch seems to get around this.
SO... we hope to be supporting a pretty large list of adapters pretty soon. If you have one you want tested, contact us at
sale@appAuto.com and we'll see what we need to do.
Thanks!
