toofastforyou
2FAST4U
- May 25, 2001
Are there some members here who use this type of boost valve? It's made by Turbonetics and has a knob on top does some nice little "clicks" so you won't mess up your settings if you accidentally touch it while working under the hood. I also noticed that there is a little brass fitting with a tiny orifice in it on the back of the valve...I think (but not 100% sure) that's where the valve "bleeds" some air to control the wastegate's opening. Also the two ports to which you connect some hoses are marked "IN" and "OUT". I blowed through it and it seems that only the "OUT" port bleeds air out through the back of the valve. The "IN" port is probably intended for those who use an external wastegate and probably isn't used with a stock-type wastegate...Is that right?...
Anyways, any advice would be welcomed...
Thank you,
Claude. :wink:
Thank you,
Claude. :wink:
