novaderrik
- May 12, 2004
i pulled the motor and trans out of my car yesterday to do some cleanup, seal some leaks, and put some better parts in the trans.
anyways, since i had it out i'd see what i had. i knew the motor wasn't the original- the guy i bought it from said the stock motor blew up in late '92 and he put a parts store replacement long block in it- which promptly blew a head gasket in the spring of 93 and got parked until i got it in 2004...
so i wrote down all the numbers and looked over at Turbo Regal Web Site to see what i had.
the block is a 25506397 which is a late 70's carbed motor.
the heads are 25506393, which are 80-81 castings.
the rods have 3 dots and no two have the same numbers on them.
i couldn't see if the crank had the rolled fillets, but i doubt it.
but it does have the correct baffled oil pan, so that's something. i think it also has the correct turbo flexplate on it..
looks like i need to find me a 4.1 and some money. i think i know of a 4.1, which only leaves the $$$ problem.
