TV Cable Question
Hi Guys,
I finally took my car out for a test run after installing the CK recalibration kit and servo for my 200-4R. This thing shifts soooo nice and feels real good on the shifts. No more Trans-Go downshift bang! I didn't want to get into it too hard, fresh engine- keeping an eye on gages and stuff. (found an oil leak but no trans leaks):biggrin:
I started out in 4th. pulled out on the road and started to feel the shifts. They felt good for what I was excellerating at, but I was in 4th before I knew it. I knew it hit 4th because I felt the engine bogging. So I drove it around in 3rd, got a little more agressive. BIG SMILE shifts nice. Thanks CK Performance:biggrin:
The smell of oil on the headers make me park it for inspection.
Question:
Which way from this position must the TV cable go? (hoping this is TV cable adjustment). I can never get any cable clicks, it's all by feel.
With the carb at wide open throttle, do I pull more cable out or give it more slack for later shifts ?
Thanks for any help and thanks Chris @ CK Performance
its best
to leave it at full detent when you go thighter it takes away from wot . push tab in and slide it all the way in toward the firewall then let off tab. push gas pedal all the way to the floor and you will hear & feel it adjust itself .. click click click done ..
Thanks OIL MAN
No matter how many times I tried doing it that way with the clicks, I could not get my cable to click.
It's a new cable and all but had used it last summer. I also got no clicks out of it so I had to set it manually then felt good.
At least I know now that my cable has to be tighter, I'll just go a bit at a time.
Is there any particular position of the cable that is BAD for our tranny's?
D
Lonnie Diers has a great article on Extreme Automatics about the abjustment of the TV cable. Check it out!
If you can't get any clicks you may want to try the Pressure method.
http://www.jakesperformance.com/TV_Cable_Setup_Info.html
BTO has a good 3-Part TV 101 Article, Bowtie Overdrives | TV Made EZ also Pressure Info. Bowtie Overdrives | TV Made EZ recommends Min. of 2 lbs more Pr. when TV cable is connected to Throttle.
You will need a 0-300psi Gauge.
Example>> ATD Tools 5550 Automatic Transmission and Engine Oil Pressure Gauge Kit | SJDiscounttools.com
Amazon also has these w/free S/H on many.
