WARBIRD1989
- Jul 25, 2004
Can anyone tell me at what point you should consider upgrading your mass air sensor? How fast can you go with the factory original, I am presently running 11's with no problem using the factory unit.
A second question, does anyone have a link for a wastegate controller (the check ball type) that uses a cable so you can regulate from inside the vehicle..
Stephen
Stephen
