Under the hood plug ins.
mred355
Hi Guys. I am having a problem hooking all the wires back up. I did a valve job and timing chain and sprockets and have it all back together. I should have marked all the wires that I unplugged to work on the engine; but I didn't. silliy me. Now I can't figure out what goes where. Any help or direction would be greatly appreciated. Thanks in advance.
Ed
this might help ,
not shown is the connection at oil sensor psse side , crank sensor driver side by balancer , alternator field wire , a/c clutch -hi pressure cutoff at compressor rear , and the ac fan control switch on the ac line
and behind the ac compressor is the fuel prime and tach wire connectors ..dont plug them together
