Maybe someone can help me understand these P/L numbers??? I took off at a steady incline as not to spin the tires till 2nd gear and then pushed it open till 5725 RPMs where I blew off the same intercooler hose.. Well here are the p/l #s
ECM AFR 6.7:1
MAF 256.0 G/S
LV8 255
TPS 3.38 V
RPM 5725
Waste gate 90.6%
speed 47mph
IAC 87
Prog Idle 838 rpm
WB AFR 14.18:1
Map 262.73 KPA
EGT 33 DegF
Temp 165
Intake Air 66
Ing Volts 14.5 V
Boost 22.4
X-Counts 55
Advance 24.7 Deg
Knock Ret 1.6
Injector PW 15.11 MS
Injector Duty 72.2%
If anyone can tell me if these # are going in the right direction?? Thanks AL
ECM AFR 6.7:1
MAF 256.0 G/S
LV8 255
TPS 3.38 V
RPM 5725
Waste gate 90.6%
speed 47mph
IAC 87
Prog Idle 838 rpm
WB AFR 14.18:1
Map 262.73 KPA
EGT 33 DegF
Temp 165
Intake Air 66
Ing Volts 14.5 V
Boost 22.4
X-Counts 55
Advance 24.7 Deg
Knock Ret 1.6
Injector Duty 72.2%
