Frank Darcy
85gmgn
- Jun 11, 2007
I just finished installing a new turbo center unit on my 85 GN. The old turbo was shot. Tons of play. I was getting very low oil pressure even with new main and rod bearings.
I started the car, and it fired right up. I was happily surprised to see my oil pressure go right up to 70 lbs at idle cold. I figured the turbo bearing being shot was dumping the oil pressure. My oil pressure sensor is on a tee right on top of the turbo where the oil feed is. So the car is running fine, no smoke, good oil pressure. I ran probably 5 to 10 minutes and when I added a little throttle, I started blowing incredible amounts of white smoke out the tail pipes.
On the humorous side, my two neighbors came over because they thought the garage was on fire. Is it too much of a coincidence that I could have lost a head gasket? Prior to replacing the turbo, the car was running a little hot and I was getting some bubbling back into the overflow tank. Do you guys have any other suggestions? Is there any reason why the turbo would fail?
