I decided to redo the fuel and brake lines on the car while the body was off the frame. I went with a 5/16 for the return. What is the best way to attach to the regulator? An adapter fitting at the regulator to a -6 and braided hose to the hard line at the frame? Or try to attach to the factory flex hoses? Are they to restrictive? Only running a 255lph right now and have trouble getting fuel pressure down to 42. But the lines were gummed up and rusty. I've read about drilling out the Saginaw fittings, but can't find out what is actually being done. Even if the mod is done, will it flow better, or is there restrictions between regulator and the end of the hose?
