- Aug 11, 2001
86/87 Buick Grand National, Turbo Regal, T Type & Turbo T Performance Parts: Turbo, Intercooler, Injectors, Standalone, Engine, Intake, plus more….
With 30+ years in the game and 3 cars I am finally cleaning out the garage so I can concentrate on one car to try and make BG this year after a 32 year absence. If part is not pictured I can post or send you the most recent pictures with the date.
Everything must go, it doesn’t mean i’m giving it away. I’m flexible and open to offers, but let’s be realistic (lowballers will be ignored and or BLOCKED!). PLEASE do NOT waste MY time, serious buyers only, PLEASE!!! Don’t hesitate to ask any questions you might have. Preferred Cash local pickup, especially for the bigger items. Local pickup is Oceanside (Long Island), NY 11572
I have so many parts that I had to split them into 2 posts (one Engine & SUSPENSION and the other is all Electrical Components). Keep an eye on this post as I keep it upto date and add more parts as I sell off some of these parts.
SHIPPED= Price to the Lower 48.
(NEW)= Brand New
(BNIB)= Brand New In Box/Bag
(MOCKED)= New but previously bolted on but never used or ran
(Like New)= Slightly Used with approximately 1,500 miles
(USED)= Used
ENGINE/TURBO PARTS:
30) Stage 2 On Center 153 Virgin block with New Arp Main Cap stud kit (NEW)_$5,900
38) Comp Cams XR3 216/220 Hyd Roller Cam with Morel Lifters (Like New)- $500
63) HD Wastegate Solenoid for Stock style & TA housing (USED)- $85 shipped
**64) 3” Intake (MAF) pipe coated black w/12 inch cone filter (Like New)_$120
**68) RJC Racing PCV (BNIB)_$30 Shipped
**69) NOS Turbo Wastegate Vacuum Line Hose_$180 shipped
SUSPENSION/EXTERIOR PARTS:
81) Detroit Speed Rear Tubular Sway Bar Kit (1 ⅛”) Diameter (Like New)_$290
86) F Body Radiator in great condition (Like New)_$50
87) Rear Trunk Spoiler complete with both ends and OEM quarter End caps- (USED)_$900
88) OEM quarter End caps- (USED)_$45
91) Front Rotors Grooved with new bearings (Standard Lugs, NOT METRIC) (Mocked)_$150
ENGINE/TURBO SOLD PARTS:
SOLD……31) Champion Racing Heads Irons (B-Hive Pac 1218 Hyd. Roller) (Like New)……SOLD……
SOLD……32) T&D 1.55 Rockers for Iron Heads (Like New)……SOLD……
SOLD……33) Champion Racing Irons with Wire Lock, these were the original run of heads before they stamped them with the Champion CNC name. (they worked great and I never blew a headgasket, these need to be freshened up) All ports are the same exact measurements as the ones that are sold today (USED)- (includes 3 correct Fel Pro gaskets) ……SOLD……
SOLD……34) Champion Racing Heads Upper & Lower intake w/ billet fuel rail (Like New)…SOLD…
SOLD……35) Champion Racing Heads IAC relocator (Angle Boss) (Like New)……SOLD……
SOLD……36) Champion Racing Heads Throttle Body Vacuum Block off plate (Like New)……SOLD…
SOLD……37) Precision Turbo PTE GEN 2 PT6266 DBB .85 A/R (Mocked)……SOLD……
SOLD……39) Comp Cams 206/206 Hyd Roller & Comp Cams Roller Lifters (NEW)- (lifters were put into a bucket of oil but never used or installed)……SOLD……
SOLD……40) TA Valve Cover (Like New)……SOLD……
SOLD……41) Harland Sharp Heavy-Duty Roller Rockers 1.60 (S60360K) (BNIB)……SOLD……
SOLD……42) Billet Aluminum T-Stat (Thermostat) Housing & Clamp combo (Like New)…SOLD……
SOLD……43) GN1 Throttle Body 72mm (no need for IAC relocator/angle boss)……SOLD……
SOLD……44) GN1 72mm Throttle Body Power 6 Plenum Only (Mocked)……SOLD……
SOLD……45) GN1 Billet CNC Throttle Body 1" Spacer Tapped for Vacuum……SOLD……
SOLD……**46) Champion Racing Billet Fuel Rails For Stock Intake Manifolds (Mocked)…SOLD…
SOLD……47) GN1 KB3 SS Headers w/46mm Wastegate, Blow Off Tube & BC (Mocked)…SOLD…
SOLD……48) GN1 3" Down Pipe with a Flat Flange no Wastegate & w/Test Pipe (Mocked)…SOLD…
SOLD……51) Racetronix Fuel Pump Hotwire Harness (USED)……SOLD……
SOLD……52) Racetronix Fuel Injector Hotwire Harness (1 piece harness) (USED)……SOLD……
SOLD……49) Racetronix Teflon Fuel line Kit and Filter (-8 feed & -6 SS braided black conductive coating)_ need AN fittings at pump (Like New)…… SOLD……
SOLD……50) Racetronix Billet Fuel Psi. Regulator (BNIB)……SOLD……
SOLD……53) Accufab Fuel Pressure Regulator with 2x O-Rings (Mocked)……SOLD……
SOLD……54) Accufab 70MM Throttle Body (bead blasted- Not Polished/flat) (BNIB)……SOLD……
SOLD……55) Precision plenum (bead blasted- Not Polished/flat) (BNIB)……SOLD……
SOLD……56) RJC A/D Power Plate for Precision plenum (BNIB)…… SOLD……
SOLD……57) RJC Drivers Valve Cover Breather (Mocked)…… SOLD……
SOLD……58) RJC Valve Cover Extensions (BNIB)……SOLD……
SOLD……59) RJC A/D Power Plate for Stock Plenum (Like New)……SOLD……
SOLD……60) 3" RJC DP w/test pipe (O2 Bung on the bottom, w/bung cap/plug)(Like New)…SOLD…
SOLD……61) RJC 315 FMIC w/blk pipes (3 holes on up pipe for Alky&Vacuum, Like New)…SOLD…
SOLD……62) BGC Stretched SLIC (has some cosmetic damage on the backside and air scoop, will need to be psi tested) (USED)_……SOLD……
SOLD……**66) Melling K-20IHV High Volume oil pump kit (BNIB)……SOLD……
SOLD……**65) Braided Turbo Oil Return line (Mocked)……SOLD……
SOLD……**67) RJC Boost Controller (BNIB)……SOLD……
SOLD……**70) Polished Acufab 70MM Throttle Body……SOLD……
SUSPENSION/EXTERIOR SOLD PARTS:
SOLD……80) UMI Performance Rear Non-Adjustable U&L Control Arm Kit 302116- (BNIB)…SOLD…
SOLD……82) HR PartsNstuff 3.8 Drivers side Motor Mount (Like New)_……SOLD……
SOLD……83) HR PartsNstuff Transmission Mount (Like New)_……SOLD……
SOLD……84) Wilwood D154 Front Caliper Kit (Like New)…… SOLD……
SOLD……85) Power Antenna-Universal (BNIB)……SOLD……
SOLD……89) Eastern Perf 3” High Perf. Catalytic Converter- (New, has surface rust)……SOLD……
SOLD……90) Dennis Kirban Rear Seat X-Brace kit- (USED)……SOLD……
(NEW)= Brand New
(USED)= Used
ENGINE/TURBO PARTS:
