As most of you know my nephew died in a crash in a buddies T-Type back in July. His parents gave me his car, and I decided to finish off what he was dreaming about doing with his car instead of just putting it back together. He had a stage 2 on center block and a 3.59" stroker crank, he had finished college, landed a good job, and was going to build his GN up to be nasty. He was finally escaping being trapped in the bang for the buck catagory of a college student. This is what I had already, purchased, or have on order:
4.1 Stage 2 on center block with no damage or sleeves, which is
actually .070" below the standard 4.1 stage bore. (its at 3.930")
BMS 3.59" stroker crank turned 20/10
6.5" Carrillo rods
BRC pistons
PTE solid roller cam
Crane solid roller lifters
Milodon gear drive
3 stage Weaver bros. dry sump oiling system
Chapman ported stage 2 heads
Crane roller rockers
Edelbrock tunnel ram converted to fuel injection
ATR coated twin turbo headers
dual ball bearing 61 turbos (GT 35R compressors) with P-trim turbine wheels
and 4 bolt .68 a/r turbine housings
A pair of 1000 hp liquid intercoolers, one for each turbo
Barry Grant king sumo fuel pump
160 # injectors
Weldon regulator
Big stuff 3 wide band ecu
MSD dis 4 ign amplifier
Built turbo 400 with Coan brake
Art Carr 9" torque convertor (should stall around 5000 rpm @ 10#)
Weld pro stars with front runners and good year 30x10x15's
Fiberglass cowl induction hood
If you look at that list you can say off the top: Stage 2 headed stroker motor with twin dual ball bearing turbos, dual liquid intercoolers, tunnel ram intake, solid roller cam, and dry sump oiling. I think the car being built up to these specs would even exceed my nephews imagination. My nephew was my very good friend and anything short of the absolute baddest / coolest set up I could come up with would not do.
This car is not being built to make banzi passes. Its being built as a memorial to honor him. The car will only make low boost 9 second passes. I can not afford to maintain a car at the 8 second level. My only performance goal for the car is to break 150 mph in the quarter. NHRA requires the car to have a parachute installed if you break 150 mph. If the car winds up with a chute installed because its fast enough to be required to have one you can say:
Is it cool.....
Twin dual ball bearing turbos, liquid IC's blah blah blah.... Yep it's cool
Is it NASTY.....
They made me put a parachute on it..... Yep it's NASTY
Is it street legal....
As long as you dont talk to an emission inspector... Yep!
Is it fast on pump gas....
STFU!
Jason
6.5" Carrillo rods
BRC pistons
Milodon gear drive
160 # injectors
Weldon regulator
Is it cool.....
Is it NASTY.....
STFU!
Jason
