BLACK MAGIC RACING
formerly turbo_canuck
- Jul 18, 2001
PARTS
86/87 parts
-2 stock intercoolers - $75 each
-GN header panel (had a small piece broken out, professionally repaired) - $200
-Pair of blue plastic t-top trims, for locking t-tops, like new! - $60
-Pair of a-pillar trims, for t-top cars, fair shape - $20
-Front and rear GN seats, driver was power, now has no bracket. decent daily driver shape - $350
-Pair of GM t-top weather strips, new, unopened - $90
-Pair of anti-rattle strips, new in boxes - $40
-Stock shifter cable - $35
-Cruise control cable (2) - $25 each
-Cruise control module (2) - $50 each
-Turbo heat shield (3) - $20
-Stock engine main accessory bracket - $75
-Stock throttle cable bracket - $35
-3 stock intercooler shrouds, far from perfect - $20 each
-Pair of stock 8445 heads, complete - $150
-4 driver side intercooler brackets - $25 each
-3 passenger side intercooler brackets - $25 each
-Passenger side intercooler bracket cut for stretch intercooler - $20
-Stock oil fill tube and cap - $25
-3 stock turbo cores - $75 each
-stock front swaybar - $40
-stock balancer - $75
-stock water pump pulley - $20
-3 stock a/c compressors - $40 each
-2 stock turbo crankshafts - $150 each
-Chrome tail lights - $60 each or $100 pair
-Driver's side GN tail light assembly (chipped corner) - $60
-Passenger side taillight lens only, no bezel - $40
-Heater blower motor + fan - $40
-2 Stock flex plates - $30 each
-2 stock plenums - $30 each
-109 engine block, standard bore - $275
-2 Stock passenger side headers - $60 each
-Stock cam sensor - $40
-Like new stock oil pressure switch - $20
-Tinted rear defrost window - $75
-Stock intake - $250
-2 stock fuel rails - $70 each
-Pair of new INSIDE door dew sweeps - $40
-Pair of stock rocker assemblies - $35
-Solid driver side fender - $45
-Solid passenger side fender - $45
-Set of stock rods - $40
-Rear coil pack brace - $15
-Stock 2 BAR MAP sensor - $25
-3 Transmission dipsticks w/ tubes - $40 each
-2 Engine oil dipsticks w/ tubes - $35 each
-2 Used alternators - $60 each
-2 pairs of stock axles - $ 60 each pair
-6 rear alternator bracing brackets - $20 each
-2 powermaster cores - $100 each
-2 turbo to head brackets - $30 each
-2 stock vaccuum blocks - $20 each
-2 A/C compressor "L" braces - $10 each
-2 Alternator/compressor "Y" brackets - $20 each
-5 Flywheel inspection covers - $30 each
-Stock oil pan - $65
-3 Used GM knock sensors - $35 each
-BRF transmission for core - $275
-2 used Stock front covers - $75 each
PERFORMANCE PARTS
-6" long PTE reducer hose, 2.5-3" black - $20
-2.5" to 3" reducer hose - blue - $20
-LOKAR trans mount braided stainless trans dipstick + tube - $50
-Misc. intecooler hoses, 3", black, blue, 4" red, blue - $10 each
-2.5" 45* elbow , red - $15
-Wiseco forged pistons for 4.1, 3.965" bore, clearanced for stroker - $200
-FAST jumper box/harness for sequential - $200
-ATR external wastegate - $100
-Pair of Stage 2 Valve covers - $65
-Complete set of hooker headers - $350
-Hooker 2.5" test pipe - $20
-3" SS test pipe with dump, repaired where pipe expander split it, - $35
-Comp hi-tech moly pushrods, stock replacement - $50
-Bosch 237 fuel pressure regulator - $30
-B+M Starshifter - $ 150
-2 Laptop adapters, USB to serial port, for FAST - $35 each
-Sequential electronic tail light kit - $125
-4 Keystone turbine wheels, slotted, 2- 15x8, 2 14x7 -$100 set
-4 GTA wheels, gold centers, non- dimpled, 2 fronts, 2 rears, one stripped, light curb rash - $300
-4 87 turbo-t/85 gn wheels, all painted black between spokes, clear coated, with new center caps, like new Goodyear eagle GT2's - $600
84/85 Hotair parts
-Engine accessory bracket - $25
-Braided down pipe - $25
-4 '84 t-type wheels - $150
-83 regal header panel w/ grill - $150
-Pair of mint chrome headlight bezels - $125
V8 BUICK PARTS
-Autometer sport comp mechanical oil pressure guage - $25
-Autometer sport comp mechanical fuel press. guage- 0-15 lbs - $25
-Autometer sport comp mechanical vaccuum guage -30-0 hg - 25
-New Poston frame pads for 455 swap into regal, 64-65 skylark - $70
-Stock 350 exhaust manifolds - $80
-350 alternator/AC bracket - $35
-Stock 72 4 barrel intake - $75
-Low miles B.O.P. TH350 transmission, built to handle 650hp - $500
-B+M torquemaster 10" converter, 3200-3500 stall low miles, $175
-TA 310 hydraulic flat tappet cam + lifters, low miles, for 350 - $175
-TA competiton 350 headers - $295
-1972 350 quadra-jet, fresh rebuild+power valving - $250
-350/455 non-A/C alternator bracket - $70
-Pertronix-converted 72' 350 distributor - $125
-Ported + Polished '72 350 heads - $700
-TA 350 aluminum stage 1 intake - $300
-Like new 350 mechanical fuel pump - $25
prices do not include shipping from canada.
86/87 parts
PERFORMANCE PARTS
84/85 Hotair parts
V8 BUICK PARTS
