To answer your question, yes and no.
See on the smaller Hi-impedance injectors its a non issue. When we start having problems is when the lo-impedance ones get used. These would be the 72's, 75's, 83's, 96's, 160's..etc.. typicaly on the lo-imp injectors the idle is what gets hit.. the larger the injector, the more issue it becomes. Hard to idle 160's at 800 rpms.. and then the computer plays a major role. There is no issue idling 75's or 83's with an aftermarket DFI.
As far as 36's, 009's, 50's, 60's.. they all will idle the same. I just have a preference with the 50's since their track record has been better getting figured out. In other words, they are plug n play with the corresponding chip.
HTH
