Upper Plenum Bolts
salvageV6
Daily Driver
I need to know ASAP what size and length the stock 5 upper plenum to intake bolts were? :confused:
Installing my Race Jace plate and J. J. upper plenum and throttle body, but the bolts I took off were through my old Kenne-Bell plenum spacer and are way too long.
Couldn't find it in the manual either...
TIA
If memory serves correct, they are 8mm X 25mm. Don't forget to chase the threads before installation.
HTH
Jim
I think the stock ones are too short. Try going a hair longer than the stock ones to help prevent stripping.
Well normally if they thread in and work I leave them. ;)
This time I actually went to Sears Hardware store and got the right ones, even 5mm longer to avoid messed up threads. :rolleyes:
M8 x 30mm standard thread. Expensive at $4 for 5.
