Little6pack
- Jun 2, 2002
Fifteen New Regulations in the USA Dept of Transportation Drivers 2004 Handbook
1. Turn signals will give away your next move. A confident
driver avoids using them.
2. Under no circumstance should you maintain a safe distance between you and the car in front of you, because the space will be filled in by somebody else, putting you in an even more dangerous situation.
3. The faster you drive through a red light, the less of a chance you have of getting hit.
4. Warning! Never come to a complete stop at a stop sign. No one expects it and it will result in your being rear-ended.
5. Never get in the way of an older car that needs extensive bodywork,especially with NH, IL, MN, or IA plates. With no insurance, the other operator has nothing to lose.
6. Braking is to be done as hard and late as possible to ensure that your ABS kicks in, giving a vigorous, foot massage as the brake pedal violently pulsates. For those of you without ABS, it's a chance to strengthen your leg muscles.
7. Never pass on the left when you can pass on the right. It's a good way to prepare other drivers entering the highway.
8. Speed limits are arbitrary figures; given only as a suggestion and are not enforceable during rush hour.
9. Just because you're in the left lane and have no room to speed up or move over doesn't mean that a driver flashing his high beams behind you doesn't think he can go faster in your spot.
10. Always brake and rubberneck when you see an accident or even someone changing a tire. This is seen as a sign of respect for the victim. And always checkout blondes in distress.
11. Learn to swerve abruptly without signaling. USA is the home of high-speed slalom-driving along on major Federal highways; thanks to many of the state Department of Highways, which puts pot-holes in key locations to test drivers' reflexes and keep them alert.
12. It is ok to honk your horn at cars in front of
you that do not move three milliseconds after the light turns green.
13. To avoid injury in the event of a collision or rollover, it is
important to exit your vehicle thru the
windshield right away. Wearing your seat belt will only impede
your hi-velocity escape from danger.
14. Remember that the goal of every driver is to
get ahead of the pack by whatever means necessary.
15. Flipping the bird' is considered a polite salute.
This gesture should always be returned.
Thank You,
> The US Dept. of Transportation
Thank You,
