V4 Fit???
Vader 87
Licensed
Does your V4 sit off center from the turbo??? Mine is currently sitting to the left and i cant get it to line up...is this common?
thanks
Jason Mizell
Mine didn't. I had to reclock my turbo a little so the outlet was a straighter shot to the V4 inlet. Aren't the bracket holes slotted for side to side adjustment at the IC?
As a side note, I recently replaced my sway bar mount bushings and endlinks and now my V4 fits much better around the sway bar.
Tom
In a word..
Yep.
I tried the V4S which was supposed to be the stock replacement. Ended up drilling my I/C brackets before I decided that it wasn't worth it. Sat WAY off center and wasn't level. That's on a straight, 20k mile car.
Others may have had different experiences though.
Rich
well i got her to sit straight.....how much clearance is needed around the sway bar??? i have about 1/2 an inch all around....i too have just replaced all my bushings etc.
