I have an 87 GN that I can not get to start because I have no spark at the plugs. This started about 4 months ago with the car running all-right around town, but the car would shut-off if you had your foot in the gas when it reached about 12# of boost ( if you let off the gas the car came right back to running and was fine as long as you were just driving normal. I tried it a couple of times and held the gas pedal to the floor and the car came back once and was pulling hard but I let off immediately ). Then the car started having alot of rich black exhaust smoke all the time. This went on for about a 3 or 4 day period in which the car was driven very little. Next the car would not start at all. I have put a timing light on all of the plug wires an I only get a blink every once in awhile or not at all. When I do get a blink all the plugs must get one because you can hear a difference in they way the engine is cranking, like it wants to start. I have swapped out the ignition module coil pack assembly, computer, cam and crank sensors. I have tried to follow the service manual and have voltage where it says I should, but I still have no spark. I have checked the engines compression and it has 140# to 145#'s. Before the car quit running, but was shutting down, I changed the injectors for 009's and a new chip, and also swapped out the oil pressure switch. I have checked the fuses in the main fuse block that have ignition or fuel pressure listed by them and they are all OK. I though it might be the factory security system, but in checking that on another GN, it only stops the starter from working, and the starter is working fine on the car that won't run. I am open to any and all help and opinons. If you know of any fuses anywhere else, have had a problem like mine, anything that might get me going please reply.
