Finished the conversion. The pedal conversion was a PIA as expected. Just followed the RR nstructions and it was paint by numbers
There is a bit of difference when hitting the brake after running up the boost a bit but guess that is a good trade of for the expected dependability.
Have not tried any launches under boost yet.
now the questions.
If I ever want to go back to the PM setup, can the vacuum pedal be used?
Is there a difference when using a Tee off the PCV vacuum feed or using a 6 port TTA vacuum block?
Thanks in Advance
now the questions.
Thanks in Advance
