vaccum problem, need help
turbotoyz
under reconstruction!
i have had a KR problem for awhile and decided to check all the vac since it seemd to be ok but i put a vaccum guage on the system and the needle goes nuts but it is above 15 inches and going 90 to nothing, what is happoning is that meaning there is a leak or is it just barley keeping up? :confused:
one of the hard lines from the vac block to the map sensor i just took the hose off to the map and started the car and the needle goes nuts??
